AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
coordinate tracker only displaying 2 decimal places
3 REPLIES 3
2623 Views, 3 Replies
All,
I have a map which is using the DLTM coordinate system, so I'm using the coordinate tracker to display the Lat and Longs in decimal degrees, but it's only showing them to 2 decimal places, which is as good as useless. Displaying them in Degrees, Minutes and seconds works fine, but I really need them as decimals, they used to work fine, so I'm not sure what's changed.
Any help would be appreciated.
I'm using Map 3d 2007
3 REPLIES 3
Set the precision for your units to more than two places.
From the Classic Map workspace Format > Units
From the Geospatial Workspace Setup > More Formatting Options > Units
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
wrote in message news:5641464@discussion.autodesk.com...
All,
changed.
It's sorted, I had to go to "setup", "more formatting options", "units", under Length, I selected Decimal, and then changed the precision to 0.000000.
I just had the same issue, went out to the Drawing Utility tab (upper most left hand corner) AutoCAD Map 2013; then to Units and set the decimal accurracy-precison out to five ex. 0.0000
Works great now can track coordinates in degs min sec and decimal at the same time.
Thank-you
