My problem:
I've been supplied a drawing that has the wrong coordinate system assign to it, it's has UTM83-11 instead of UTM83-10.
What I'm doing so far is:
I attach the drawing into a new drawing (with the correct UTM assigned), via TaskPane - Map Explorer - Drawings - Attach.
Then I add it to the drawing via Task Pane - Display Manager - Data - Add Drawing Data - Query Source Drawing - Location - All.
This displays the original drawing in the correct place.
Great so far.
Now I want to import the corrected Autocad entities.
Any ideas?
It feels like a just missing the final step, but I'm not sure what to do.
Using Civil 2012
Solved by antoniovinci. Go to Solution.
After querying, save all with a new filename, restart Autocad and load the latter, sir.
