AutoCAD Map 3D General Discussion
Member
0 Kudos
Post 1 of 4
Coordinate System Library not showing all of the Coordinate Systems
261 Views, 3 Replies
07-19-2012 05:18 PM
I am using Civil 3D 2012 with SP1. When I use data connect and attempt to edit the coordinate system the Coordinate System Library that pops up only shows 5 No Datum coordinate systems. The Datum box under Show is uncheck, unfortunately it is also greyed out and uncheckable.
How do I get this box checked?
Thanks.
Active Contributor
0 Kudos
Post 2 of 4
Re: Coordinate System Library not showing all of the Coordinate Systems
07-20-2012 05:01 AM in reply to: mikebaldi
Not sure but problem seems to me is Map 3D installation
Anand
Member
0 Kudos
Post 3 of 4
07-20-2012 11:19 AM in reply to: TATA_JUNE2007
are your boxes greyed out?
Product Support
13 Kudos
Post 4 of 4
07-25-2012 07:09 AM in reply to: mikebaldi
I'd first try running the program as Administrator and see if you then get access. If you do, turn off UAC and try again.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
