AutoCAD Map 3D General Discussion
tom
Member
tom
Message 1 of 2 (432 Views)
Coordinate system error
432 Views, 1 Replies
08-02-2012 08:12 AM
I get an error message when I load a map with Map 2009 (XP) that was last saved by 2012 (Win7 x64).  The error message is this:
Warning: Drawing {drawing name} was created with a version of coordinate system {coordinate system name} that is different from the version installed on your system.  Coordinate conversion operations may generate incorrect results.
I tried opening and saving it with 2009 but the error persists.  What causes this error and what can be done about it?
Tom
Alfred.NESWADBA
Message 2 of 2 (397 Views)
Re: Coordinate system error
08-05-2012 01:14 PM in reply to: tom
That with Map3D2012 there are a lot more coord-systems available then in 2009. And when you now open the drawing with an older Map3D version you either have not defined this coord-system or with other definition-details.
If you can verify that your 2009-version has a projection-system defined equal to that of 2012 then you should be able to assign it using the command _ADESETCRDSYS.
If you have not the same coord-system in your 2009-version you will be unable to mix data of different systems with your Map3D and this drawing.
- alfred -
Alfred NESWADBA
