AutoCAD Map 3D General Discussion
New Member
andyb475
Message 1 of 4 (197 Views)
Coordinate space Map 3D 2008
197 Views, 3 Replies
06-05-2012 06:14 AM
I am fairly new to AutoCAD and I am running into a problem. I have a drawing wherein the drawing has no coordinate system defined (or so it seems). I have assigned the correct C.S. but when I export/import a SHP file I find that the drawing is in the wrong splace. I have attached a screen shot to show the problem I am having. Can anyone tell me how I can move the entire drawing to the correct spot? Any help would be greatly appreciated.
Andy
Thanks for all the info. The company that created the drawing altered the coordinates (decimal to architectural) and somehow moved the position of the drawing. I was able to reassign the coordinates to the correct one and then rubber sheet the layers to my reference shapefile.
antoniovinci
Message 2 of 4 (183 Views)
Re: Coordinate space Map 3D 2008
06-05-2012 08:38 AM in reply to: andyb475
Command: _ALIGN
Distinguished Mentor
thepworth
Message 3 of 4 (177 Views)
06-05-2012 10:28 AM in reply to: andyb475
check your units - your lower left corner is indicating feet & inches - I recall seeing a post lately that Map prefers using feet/meters, but not sure if it applies here.  check units & insunits for insertion units.
Best of Luck!
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
New Member
andyb475
Message 4 of 4 (173 Views)
06-05-2012 11:42 AM in reply to: andyb475
