AutoCAD Map 3D General Discussion
New Member
andyb475
Message 1 of 4 (194 Views)
Coordinate space Map 3D 2008
194 Views, 3 Replies
06-05-2012 06:14 AM
I am fairly new to AutoCAD and I am running into a problem. I have a drawing wherein the drawing has no coordinate system defined (or so it seems). I have assigned the correct C.S. but when I export/import a SHP file I find that the drawing is in the wrong splace. I have attached a screen shot to show the problem I am having. Can anyone tell me how I can move the entire drawing to the correct spot? Any help would be greatly appreciated.
Andy
antoniovinci
Message 2 of 4 (180 Views)
Re: Coordinate space Map 3D 2008
06-05-2012 08:38 AM in reply to: andyb475
Command: _ALIGN
Distinguished Mentor
thepworth
Message 3 of 4 (174 Views)
06-05-2012 10:28 AM in reply to: andyb475
check your units - your lower left corner is indicating feet & inches - I recall seeing a post lately that Map prefers using feet/meters, but not sure if it applies here.  check units & insunits for insertion units.
Best of Luck!
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
New Member
andyb475
Message 4 of 4 (170 Views)
06-05-2012 11:42 AM in reply to: andyb475
Thanks for all the info. The company that created the drawing altered the coordinates (decimal to architectural) and somehow moved the position of the drawing. I was able to reassign the coordinates to the correct one and then rubber sheet the layers to my reference shapefile.
