"Mickbuckley" <Hi,
href="mailto:michael.buckley@etol.co.uk">michael.buckley@etol.co.uk>
wrote in message
href="news:f15e46d.-1@WebX.maYIadrTaRb">news:f15e46d.-1@WebX.maYIadrTaRb...
I have a DWG file containing blocks with attributes
I would like to
convert the attribute data to object data
is this possible?
Mick
"Murph" <Jmurphy@cemc.org>
wrote in message
href="news:CD04A61348F1198198776C50D1A775A3@in.WebX.maYIadrTaRb">news:CD04A61348F1198198776C50D1A......
What version of MAP?
You can do it a couple of ways, either with a
custom app VBA/Lsp or the simple way that might work is by exporting the
blocks to an ESRI shp file. Then import that shp file in assigning data to
object data table. You might need to redefine the block with out attribute
prior to the import.
Murph
"Mickbuckley" <Hi,
wrote in message
I would like to
is this possible?
Mick
"Mickbuckley" <Hi,
wrote in message
I would like to
is this possible?
Mick
"Kevin W. Garnett" <
href="mailto:kgarnett@osmre.gov">kgarnett@osmre.gov> wrote in message
href="news:7EE89FA12D7B4CE86D152369EA53E0F9@in.WebX.maYIadrTaRb">news:7EE89FA12D7B4CE86D152369EA5......
how about the generate links command.
doesn't that take block attributes and convert them to OD?
wrote in message
href="news:CD04A61348F1198198776C50D1A775A3@in.WebX.maYIadrTaRb">news:CD04A61348F1198198776C50D......
Murph
"Mickbuckley" <Hi,
wrote in message
I would like to
is this possible?
Mick
"Vic" <vic@gcshouston.com>
wrote in message
href="news:AECFB09F19F8F744617D965106CDB8A3@in.WebX.maYIadrTaRb">news:AECFB09F19F8F744617D965106C......
Mick
You might be able to use Map/Database/Generate
Links... Be sure the field names in the object data table are the same as the
tag names in the block & select Create Obkect Data Records instead of
Create Database Links.
"Mickbuckley" <Hi,
wrote in message
I would like to
is this possible?
Mick
"SonzofGod" <I
href="mailto:nlherd@ci.columbia.mo.us">nlherd@ci.columbia.mo.us> wrote
in message
href="news:f15e46d.5@WebX.maYIadrTaRb">news:f15e46d.5@WebX.maYIadrTaRb...
would love to have that VBA routine as well! I started that other thread "VBA
routine to convert attributes to text" but never got anywhere with the
routine. Check out that thread...
Nick
