AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Converting a text string to a block
2 REPLIES 2
colby82
2036 Views, 2 Replies
question for ya all out there.. so, in a drawing, i have several text strings, 's', that i would like to change to a known block... is this able to be done? there are over 3000 's' in the drawing, hoping to change them all to the same block. let me know if this can be done. thanks
colby
2 REPLIES 2
hence_the_name
in reply to: colby82
I'm not sure - maybe there is even a simple AutoCAD command for this.
Are you able to select/filter all text strings you want to convert into blocks?
If so -  here is the way I would do it (not necessarily the easiest one):
- export all your textstrings ("s") : command _mapexport, choose ESRI SHP as target file format, export as "text".
- import the file again (command: mapimport) - you can import the text objects (basically  points with text attribute) as blocks
To import the text as block:
- in Import dialog box, click on <acad_point> in "Point" column
- click on small button appearing on the right
-in dialog box "how to process points?" choose "As blocks" and select the block you want your text converted into
Good Luck,
Rob
http://raumpatrouille3d.blogspot.ch/
colby82
in reply to: hence_the_name
Spoiler
i was able to get some help on another CAD board, someone wrote me a quick routine.
”Boost
