Dear all,
The perennial question of converting 3d polylines to 2d polylines. In Civil3D 2014 under modify there is a command to convert 3d polylines to 2d polylines.
Is there something similar for MAP3D 2014 or I need to resort to LISPs?
Thank you for your help.
Festive wishes
Archaeoman
Solved by Alfred.NESWADBA. Go to Solution.
you can use command _MAPCLEAN and in the third dialog activate the checkmark for "3D-Polyline to Polyline"
The resulting elements are then polylines (LwPolyline) with an elevation (I guess from the Z-value of the first vertex).
- alfred -
...or simply _FLATTEN the selected objects to the Z=0 plane.
The result will be a mashed 3Dpoly, explodable to lines.
