AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
convert .shp files to acad point blocks
4 REPLIES 4
sbsmith
2900 Views, 4 Replies
how to convert .shp files , that import as point objects, into acad point blocks with x,y,z values and attributes intact?
4 REPLIES 4
in reply to: sbsmith
With Map 3D you can grab the dbf file and use that to create/import points
with the Civil tools. That will give you the Civil Object Point(s). If you
want them as non-civil points, you can create a block with attributes and
import the shp file using blocks and attributes option. May sure the
attribute tags are the same as the field name of the shp file.
Murph
wrote in message news:4906653@discussion.autodesk.com...
Dang you beat me to it Murph.
Tripp Corbin, GISP, MCP
Associate Vice President, GIS/Mapping
ESRI Authorized Instructor
Keck & Wood, Inc.
www.keckwood.com
(678) 417-4000
(678) 417-8785 Fax
Keck & Wood now offers Introduction to ArcGIS training classes. Contact me
for more information.
"Murph" wrote in message
news:4906656@discussion.autodesk.com...
Murph
sbsmith
NICE TRY , GUYS
I GET "Unrecognized database format" for my .dbf file
i tried different import formats but nothing worked
anymore ideas?
Did you try the map import command, not the civil import points? Create a
block from a acadpoint with the attributtes tags the same as the shp field
names. Import the shp file with the block option.
BTW "Unrecognized database format" is pretty command using anything other
than a MS Office data file.
Murph
wrote in message news:4910506@discussion.autodesk.com...
NICE TRY , GUYS
anymore ideas?
”Boost
