Open a new blank dwg, import the sdf file and allow it to create the OD
table from the attributes, then turn right around and export the autocad
objects to SHP allowing it to create attributes data from the OD tables
created when the SDF was imported.
Four simple steps.
Mapimport (select the sdf file)
Create OD data "Data column"
OK
Mapexport (name the shp file) and pick the data type (lines,
points,polygons)
Select attributes on the data tab and pick the OD table.
OK
I just try it again in less than 2 mins of work.
Murph
www.map3d.wordpress.com
"clobo" wrote in message news:5999011@discussion.autodesk.com...
um there is already data within the sdf file
I want to change it to a SHP so that it can be used with ESRI products
Message was edited by: clobo
