Hi all,
I use this now and again, linking objects with object data to a database (and converting to database links). What I want to know is, how to ADD additional objects be it 10, 50, 1000, etc. I think the problem is that the object data has the same name as the link template (which I want it to be).
It should be a simple procedure, just adding onto what I've done.
Sigurd
Hi Sigurd,
Can you take a look at the link below:
http://forums.augi.com/showthread.php?91069-Adding-object-data-to-a-feature-source
