AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Convert Additional Object OD to Database Links
1 REPLY 1
286 Views, 1 Reply
Hi all,
I use this now and again, linking objects with object data to a database (and converting to database links). What I want to know is, how to ADD additional objects be it 10, 50, 1000, etc. I think the problem is that the object data has the same name as the link template (which I want it to be).
It should be a simple procedure, just adding onto what I've done.
Sigurd
1 REPLY 1
lim.wendy
Hi Sigurd,
Can you take a look at the link below:
http://forums.augi.com/showthread.php?91069-Adding-object-data-to-a-feature-source
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
”Boost
