AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Convert 2D polyline to 3D polyline and transfer object data
4 REPLIES 4
tom_berning
8588 Views, 4 Replies
In Land Desktop there was a tool to convert 2D polylines to 3D polylines and would transfer the object data to the new 3D polyline. The 2d to 3d polyline tool in Civil 3D does not transfer the object data. I am posting this to the Map 3D board since Map deals with the object data the most and since Civil 3D is built on Map. Is there any other way to convert a 2D polyline to 3D polyline and transfer the object data?
Tom Berning
Woolpert, Inc.
Civil 3D 2020
4 REPLIES 4
antoniovinci
in reply to: tom_berning
Why do you need to transform a 2d poly in a 3d one, sir..?
A 2d poly containing an elevation attribute is easily convertable in a full 3d contour, without any transformation, by means of a simple query.
tom_berning
in reply to: antoniovinci
This is a requirement by the FAA for their eALP drawings. This has nothing to do with contours.
Tom Berning
Woolpert, Inc.
Civil 3D 2020
jdvillarreal
tom_berning
in reply to: jdvillarreal
While the lisp routine provided does act as a work around solution, what needs to be done is the 2d to 3d polyline conversion tool in Civil 3D to be fixed to include the object data.
Tom Berning
Woolpert, Inc.
Civil 3D 2020
”Boost
