AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Conversion of ngvd29 to navd88
2 REPLIES 2
1134 Views, 2 Replies
Question can map 3d convert directly between NGVD29 and NAVD88? If so, where can I find the reference for this procedure? If not is there any documentation on map 3d not being able to do this.
2 REPLIES 2
thepworth
I don't belive you can.  I'd probably suggest taking points and running them through "vertcon" from the NGS Geodetic Toolbox first before bringing into either C3D or Map3D.
I could be wrong, but I don't remember seeing it done before. 😞
Think of it as "Map2.5D" as the literature only talks about 2D Coordinate transformations....
in reply to: thepworth
Thank You.
”Boost
