AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Contours from points
4 REPLIES 4
371 Views, 4 Replies
Dear all,
I have a few points within an area of 2m x 2m and I will like to create contour lines. At the moment I can only produce models with shade difference.
Thge contour command does not accept sub 1 metre accuracy (putting 0.1m does not work).
Is there something I can do?
4 REPLIES 4
Alfred.NESWADBA
What command exactly do you use and what version of AutoCAD Map3D are you running?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
antoniovinci
I'd use centimeters (area 200x200) with 10 cm. accuracy, sir.
in reply to: antoniovinci
I will like to use centimeters but I can only select meters or inches for the creation of contours. Centimeters is not a drop down list option.
antoniovinci
Would you please paste here that XYZ points' list..?
”Boost
