AutoCAD Map 3D General Discussion
329 Kudos
Post 1 of 5
Contour shp file NG
500 Views, 4 Replies
02-01-2011 10:58 AM
I have a contour shape file of our county that is 600 mb. I can not fdo import with or without a spatial filter. I can map import some smaller regions but is a bit cumbersome.  I would like to break the file up into regions of more manageable - is there a good way to do this?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Mentor
35 Kudos
Post 2 of 5
Re: Contour shp file NG
02-02-2011 11:55 AM in reply to: Joe-Bouza
Joe
can you data connect to the file and add it to a drawing?
Is the file available online public domain?
How about intersection of grid over the data?
Dave
Member
0 Kudos
Post 3 of 5
02-03-2011 01:01 PM in reply to: parkr4st
Joe,
You might be able to simplify the lines in Map or ArcGIS. In Map the command is Simplify Objects.  In Help the procedure is listed at contour lines, simplifying with Drawing Cleanup.  In ArcGIS the Simplify Line command in ArcToolbox may be of value.  In Arc there are two options: Point Remove or Bend Simplify.  These are different and it is important to determine which one works for you.
Jay
“I have an existential map; it has 'you are here' written all over it.”
--comedian Stephen Wright
329 Kudos
Post 4 of 5
02-03-2011 02:19 PM in reply to: Joe-Bouza
When I data connect I only get fragments of the contours. No the file is not public
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
207 Kudos
Post 5 of 5
02-03-2011 03:40 PM in reply to: Joe-Bouza
The only thing I can think that may work is FDO and add with a query, instead of a spatial query use a property query. Get the major contours or at every 10, 20, 30 ft elevation, Then connect again and get 5,15,25, etc elevations.
Murph
Supportting the troops daily.
