AutoCAD Map 3D General Discussion
New Member
dfitzwater
Message 11 of 12 (169 Views)
Re: Connected shapefile only partially visible
05-21-2012 08:05 PM in reply to: areese9779
I am running into a similar issue with a shapefile that contains points.  Feature IDs 1-26 are plotting on the screen fine, however Feature IDs 27-49 are not showing up.  However, when I click on the item that is not showing up in the datatable, MAP3D will zoom and highlight where the point should be.  I have not set any thematic rules and my scale range is from 0 to infinity.  The shapefile opens correctly and shows all of the the data points in the trimble desktop software.  I have updated MAP3D 2012 with the latest service pack.  Hopefully someone has run into this before and can help.   Thanks.
New Member
dfitzwater
Message 12 of 12 (159 Views)
05-22-2012 04:12 AM in reply to: areese9779
This is an update to my issues with the shapefile not displaying all of the points.  I exported the shapefile layer data to a SDF format and now all of the points are visible.  Has anyone run into this before- can I trust a shapefile connection?
