AutoCAD Map 3D General Discussion
Active Member
0 Kudos
Post 1 of 6
Confused between Import, Connect and Attach data
239 Views, 5 Replies
07-05-2013 08:13 AM
Can you please let me know what is diffrent between Attaching, Importing and Connecting to source Data in loading data  to map process?
Thanks for your time in advance
1] you attach a drawing A into a drawing B to convert the A's CRS into the B's CRS (by query)
2] you import a resource A into a drawing B, to get a physical copy of A in B (A must be locally stored, it will be saved inside B)
3] you connect a resource A into a drawing B, to get a virtual copy of A in B (A may be stored locally or remotely, but it won't be physically saved inside B, but only as a link)
In other words: _MAPIMPORT acts like _INSERT, while _MAPCONNECT acts like _XREF.
194 Kudos
Post 2 of 6
Re: Confused between Import, Connect and Attach data
07-05-2013 11:20 AM in reply to: Behseini
Active Member
0 Kudos
Post 3 of 6
07-05-2013 01:33 PM in reply to: antoniovinci
Hi antoni
194 Kudos
Post 4 of 6
07-05-2013 01:44 PM in reply to: Behseini
Nope, an editing after _MAPEXPORT will only affect the imported copy.
Active Member
0 Kudos
Post 5 of 6
07-05-2013 02:11 PM in reply to: antoniovinci
So none of these method will change the original?
205 Kudos
Post 6 of 6
07-05-2013 04:56 PM in reply to: Behseini
No, using data connect will change the orginal data "IF" that data connection allows it. If you connect to a feature table in an Oracle Spatical database you must have the rights to write back to that database, with a connection to an ESRI shp file any changes can be write back to that file provide you have rights under the OS (Windows) to right to the folder that shp file is in. Also the dwg attach will allow you to change the orginal dwg.
Murph
Supportting the troops daily.
