AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
computer shutdowns when I use Layer Manager button
4 REPLIES 4
244 Views, 4 Replies
Has anyone experienced this. While I'm working on a drawing, I hit the Layer manager button and Map shutsdown. The problem just started. Is there a solution?
4 REPLIES 4
sorry, just AutoCADMap shuts down, not the computer. Thanks
twiebe
In talks with a Adesk tech, I was told that most of the issues with the layer manager stem from a .NET issue. The only thing I would suggest is uninstall all .net components and reinstall them. Just a suggestion.
let me know if it works
Just a note: I assume this is for Map 2007,2008
Tim Message was edited by: Tim W
Which version? search the messages in this group for crashes. there are
several replys relative to different versions
dave
wrote in message news:5799337@discussion.autodesk.com...
It is known problem if you use AcadMAP2006 with stupid MapSkin turned on.
”Boost
