AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Command script
2 REPLIES 2
suziodonnell
412 Views, 2 Replies
Command script
I am trying to write a command script. I am not a super user but have over 100 drawings that need to have the same settings changed and I was hoping to use a command script. I need to Open each drawing, hide the lineweight, save then save the drawing. So far I don't have much and I am not sure if what I do have is correct.
OPEN 2795-pscr-201-002.dwg
lweight
_QSAVE
2 REPLIES 2
antoniovinci
in reply to: suziodonnell
I'd use such a script:
filedia 0
_open drawing1
lwdisplay off
_qsave
_close
_open drawing2
lwdisplay off
_qsave
_close
_open drawing100
lwdisplay off
_qsave
_close
filedia 1
I've no Autocad at home to test it physically, so let us know if it works for you, sir.
suziodonnell
Thank you so much, that worked perfectly.
Suzi
”Boost
