I am trying to write a command script. I am not a super user but have over 100 drawings that need to have the same settings changed and I was hoping to use a command script. I need to Open each drawing, hide the lineweight, save then save the drawing. So far I don't have much and I am not sure if what I do have is correct.
OPEN 2795-pscr-201-002.dwg
lweight
_QSAVE
Solved by antoniovinci. Go to Solution.
I'd use such a script:
filedia 0 _open drawing1 lwdisplay off _qsave _close _open drawing2 lwdisplay off _qsave _close ... _open drawing100 lwdisplay off _qsave _close filedia 1
I've no Autocad at home to test it physically, so let us know if it works for you, sir.
