AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Command line, menu browser and key commands not working!
4 REPLIES 4
954 Views, 4 Replies
Gd morning all,
I would really appreciate if someone could help me...
AutoCAD Map 2010 has just been installed in my PC and since i first runned AC the command line, menu browser and key commands don´t work. This way I can´t do anything....................... The IT team from the company that I work for doesn´t understand anything about AC. I don´t know what to do!!
4 REPLIES 4
thepworth
do you have dynamic input and no command line???  can you post a screenshot - is the command line hidden (ctrl-9), or is it more nefarious - i.e. strange things can happen if it was installed while the virus protection was enabled and happened to trap some of the .DLL's used by the software - you might just have to reinstall given what you posted 😞
in reply to: thepworth
The command line is not hidden, I can see it, but when i type it doesn´t appear anything. I can also see the menu browser but when I click in it, it doesn´t happen anything. The same thing happens with the key commands (F1, Ctrl Open...). I have attached a view of the interface, I haven´t made any changes since I first runned the AC.
Thanks for the attetion,
thepworth
looks like a corrupted CUI, but beyond my experience.  what happens if you log into the computer as a different user - it would create a new profile and you can see if your configuration is corrupted or if it's the installation.
Thanks a lot, I will try it!!!!
”Boost
