Greetings,
I have used Civil 3D and a DEM to create an elevation surface with the "Blues" scheme. When I try to change the color scheme it won't change. I am using the Civil toolspace toolbar, then settings>surface styles>standard, then right click, then edit>elevations>schemes, and change to Reds, then click Apply. It goes through a processing phase, then I click OK and it goes through another processing phase, then I end up with exactly the same Blues scheme.
When I click the Prospector tab and go to Surfaces>Grid from DEM, and right click then select properties, I can see that the Scheme is Reds, but the colors below the column heading are still Blues.
Is this a bug or am I forgetting to do something.
Patrick
