Is there a way to find the RGB color saturation for attached FDO objects when they are themed. I have looked under properties but there does not seem to be a way to find it. I would like to use the same color saturation for text in the drawing that has the attached shp files. Autocad map 2013.
John
Solved by JohnPM. Go to Solution.
If you save the themed layers to a .layer file you can open the .layer file with an xml reader or notepad and get the colors in hexadecimal notation which you then can find the RBG. http://www.w3schools.com/html/html_colors.asp
The quickest way to achieve that goal, in my opinion, is:
1] in Autocad view, click Print Screen
2] in the free Irfanview, press CTRL-V
3] now SHIFT-LEFT MOUSE to copy the hex RGB value to the clipboard (e.g. black = 000000, white FFFFFF, yellow FFFF00, and so on)
