I've created a surface using a DEM file and I have a geotiff image (a map) that I would like to overlay on the surface. The problem is, the surface covers an area between the 2 maps. Is there a way to clip or crop a geotiff image that is being referenced by using the data connect?
I've tried using "mapiisert" but the image is inserted into a different location than where my surface is.
Thank you
Richele
