Is it possible to change the color, linetype, etc of a PLGRIDSYSTEM in Map 3D 2012?
Eric
Solved by eric-acevedo. Go to Solution.
Hi! Any luck with it?
I also don't like it shows coordinates around viewport. I would rather keep them within.
Yes,
using MAPLOADGRIDSTYLE you can load a xml file with the properties.
I found it on this site how to do it
http://beingcivil.typepad.com/my_weblog/2011/08/making-your-layout-look-more-like-a-topo-1.html
Attached is my xml file so you can edit the properties.
Eric
I guess that it's impossible to avoid that. I suggest to do coordinate grid at the very end or repeat procedure.
Cheers,
Vasily
Thanks for ansver
We are working in this standard(see pic)
Do you have similar xml or how you can make this?
I know this was years ago, but any chance you're still around to answer a question about your xml file......
Not having coordinate text show up every time I use it. Looking for an increment setting but having no luck.
Thanks in advance.
