AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Change original coordinate systems Autocad Map
3 REPLIES 3
712 Views, 3 Replies
 Hello, my question is very simple. Installation of Autocad Map 2012 provides a list of thousands of coordinate systems, datums, geodetic transformations, etc.. but I see that the system doesn't allows editing (they are read-only) and always I have to create new systems, new datums ... Is there any way to make it editable? Thank you very much!
3 REPLIES 3
Alfred.NESWADBA
I would not suggest to modify existing coord-systems, but to define new one you can use command _ADEDEFCRDSYS
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
The problem is that Autocad Map 2012 by default, performs a given geodesic transformation (between 2 datums) that is not valid (It is correct, but I need more precision). In my country (Spain), we used transformation grids (gsb) to make that change between two datums. If I could edit the default geodetic transformation would not have to create new datums, coordinate new systems, new geodetic transformation ... but as it is read-only ... thanks!
Perhaps with the new option "path geodesic transformation" can do something, I do not know ...
”Boost
