I added a shp file with the z value of 0 and went through the map query process to adjust the lines based on the object data elevation value, but the drawing is in miles as a units system so I end up with 72 mile high contours, is it possilbe to either scale these in 1 (z) direction or to add an additional query system to scale them down to feet?
Ron
look to that video, it shows how to query a drawing (using Map 3D command _ADEQUERY) and change the contour's elevation by using LISP.
The formula for the property alteration is:
(/ .ELEVATION 12)
...to divide the current elevation by 12 as a sample.
The link to the video: >>>click<<<.
HTH, - alfred -
(/ :Elevation@2FT_Contours 5280
in your expression the closing bracket is missing, this would be correct:
(/ :Elevation@2FT_Contours 5280)
HTH, - alfred -
