AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Change a broken FDO connection source of a join
1 REPLY 1
DS2Admin
285 Views, 1 Reply
How can the FDO datasource connection within a join be changed to a different path?
Once the datasource is unavailable the join and the join manager for the map layer do not work.  Thus I have no way of updating the datasource for the join.
This is frustrating as I need to pass map documents to users that store their data in a different location and may even name their shape file slightly different.
1 REPLY 1
hence_the_name
in reply to: DS2Admin
save layer as "layerfile" (via context menu) and edit the xml structure. Add layer to display manager again,
Rob
http://raumpatrouille3d.blogspot.ch/
”Boost
