Define an Object Data table with a character field to hold the data. Don't
attach the table to the objects.
Goto Map->Database->Generate Links, Select Enclosed text for Linkage type,
For Data links Create OD records. Choose OK. On command prompt choose All.
You will have the text in the OD table that you created.
Cheers, SIS
"Bostjan Cotic" wrote in message
news:F68EEE4B49D344A9582C2E52D355770B@in.WebX.maYIadrTaRb...
> Hello all,
> I have digitized areas and put a dtext inside as a centroid.
> this DTEXT have a value.
> Is there any way I could get this values inside topology table? or object
> data table?
> Thanks
