How can I update the data connection source for all the display map layers in my map layouts?
If I want to change the shapefile a layer is representing I can not get the layer to point to the new shapefile.
The layer seems to alway remember the name/location of the old shapefile.
If I export the layer and modifiy the value in Notepad then load a new layer from the saved and modified layer file it will change. However I would have to do this for every layer I want to change.
Is there another way to change the property of this layer in AutoCAD?
Example: I create a drawing and layout with a Display layer that points to the FDO data for shapefiles "C:\data\buildings.shp".
I then give the drawing to another worker hows data is on "E:\DATA\BUILDINGS.SHP" the data connection to the layer cannot be updated that I can see.
The problem with creating a drive alias is that it does not handle the shape file having a differant name or the shape file capitalized. I will play with that though.
Hi Todd,
ideally data is stored on network drive an shared by all users.
But if you need to adapt your layer to a different data source (e.g. file name) you could do it like this:
- in Display Manager right click on layer and save as layer file
- open saved layer file (it's xml) with text editor and modify reference to path/file name
- save file and drag it into display manager
This way you will keep your stylization.
Good luck,
Rob
As I noted this is what I am currently doing but is cumbersom to do for as many layers as I have in the drawing. If you are familiar with ESRI's ArcMap their layers datasource can be updated by finding the datasource for one layer and it then terverses the remaining layers that have broken links to their data sources and updates them based on the first one. Very quick and simple.
Civil 3D has a Data shortcut editor that is suppose to do what I need. Does anyone know if it is available for Map 3d?
