There seems to be always one.......I have someone that likes the "Map Classic Workspace". I loaded as "Planning & Analysis" when I installed. I got the Map Classic Workspace to open when they start Map 2012 by adding /w "Map Classic Workspace" to the target but it loads with the Ribbon. I went to CUI and Customoize the Workspace under Palettes..Ribbon to "No Show" but it is still showing when I close Map and go back in. Where else do I need to make a change? Why did they make something so easy so difficult? Worked fine in past verisons....why mess with a good thing?
Solved by phil_borycens. Go to Solution.
I wanted to add that everything works as expected after I open a file. The ribbon is gone, and I am in model space.
