AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Can't Get Rid of Ribbon in Workspace
21 REPLIES 21
Message 1 of 22
5632 Views, 21 Replies
There seems to be always one.......I have someone that likes the "Map Classic Workspace".  I loaded as "Planning & Analysis" when I installed.  I got the Map Classic Workspace to open when they start Map 2012 by adding /w "Map Classic Workspace" to the target but it loads with the Ribbon.  I went to CUI and Customoize the Workspace under Palettes..Ribbon to "No Show" but it is still showing when I close Map and go back in.  Where else do I need to make a change?  Why did they make something so easy so difficult?  Worked fine in past verisons....why mess with a good thing?
21 REPLIES 21
Message 21 of 22
fieldguy
in reply to: fieldguy
I wanted to add that everything works as expected after I open a file.  The ribbon is gone, and I am in model space.
Message 22 of 22
fieldguy
This is fixed in 2014 - thank you!
My custom workspace opens exactly how I want it.
”Boost
