AutoCAD Map 3D General Discussion
343 Kudos
Post 1 of 5
Can't add data
823 Views, 4 Replies
04-03-2012 02:12 AM
I'm trying to connect to a folder of SHP files.
I select all the shape files and hit add to map (before.jpg) and then the selection tick get removed and add to Map is greyed out and nothing is added to the map (after.jpg)
Any ideas as to what I'm doing wrong??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Thanks for the suggestions - I rebooted and all seems ok now
194 Kudos
Post 2 of 5
Re: Can't add data
04-03-2012 04:10 AM in reply to: neilyj
Try to load those shapes one by one, until you find out the guilty.
207 Kudos
Post 3 of 5
Re: Can't add data
04-03-2012 04:26 AM in reply to: neilyj
That's normal, did you zoom extends? Check the Display Manger to see if the layers were added there?
Murph
Supportting the troops daily.
343 Kudos
Post 4 of 5
Re: Can't add data
04-03-2012 04:46 AM in reply to: neilyj
neilyj
New Member
0 Kudos
Post 5 of 5
Re: Can't add data
06-14-2012 12:02 PM in reply to: neilyj
I'm having the same problem, but rebooting does not help.  Any suggestions?
