I'm trying to connect to a folder of SHP files.
I select all the shape files and hit add to map (before.jpg) and then the selection tick get removed and add to Map is greyed out and nothing is added to the map (after.jpg)
Any ideas as to what I'm doing wrong??
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by neilyj666. Go to Solution.
That's normal, did you zoom extends? Check the Display Manger to see if the layers were added there?
Thanks for the suggestions - I rebooted and all seems ok now
