"asg-neko" wrote in messageHello,
href="news:6141100@discussion.autodesk.com">news:6141100@discussion.autodesk.com...
I am using Map 09 (as part of or Civil 3D 09 package). We are doing a project
where we are labeling access routes with arrows. Presently, I am using leaders
for the directional arrows. They are in the base DWG that is XREF by other
sheets so to get the road the same between sheets. The problem is that the
different sheets use different scales but the arrows are only at a single size
in teh base DWG. Is there a way to have an arrow that will adjust it sizes
based on the scale used in the viewport so that the arrow will appear the
scale on a sheet using 400scale and a sheet using 100scale (similar to a color
or linetype in a plotstyle setting) ? Any help or suggestions would be greatly
appreciated!!!!
"asg-neko" wrote in messageI
href="news:6141266@discussion.autodesk.com">news:6141266@discussion.autodesk.com...
tried looking through the help menus but it didn't really make sense to me.
Are there are tips you might have? Have you used this before; if so, how did
you get things started? Also, I noticed that I can add scaled but I can't add
custom scales it seems. We use 1:400 scale quiet often but they only have
1:500.
"asg-neko" wrote in messageHow
href="news:6141595@discussion.autodesk.com">news:6141595@discussion.autodesk.com...
would you use/start them in regular AutoCAD? (I tend to use Civil 3D as
autocad alot) I've made the leader annotated via the properties menu and added
the scales that we use between the different drawings that reference the
leaders. But it seems I have to choose a scale from the list of scales I
added...is that correct? When I tested different scales and xrefed the DWG
with the leaders into the main file, the leaders didn't show up so I don't
think I am understanding how to assign these scales and such. This process, in
the end, should display the leaders as the same size whether the viewport is
at 1:100 or 1:400 scale, correct (like the line thickness in a plotstyle
setting)?
