AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
CAn Autodesk Map 3d 2015 export to a kml or kmz file?
6 REPLIES 6
rrustan
7076 Views, 6 Replies
How can I export to a Google Earth file using Autodesk Map 3d 2015?
6 REPLIES 6
Murph_Map
in reply to: rrustan
There is no export to KML/KMZ format right out of the box. You can export to ESRI SHP format then use many of the paid and/or free apps to export to KMZ. Do a google search and you should find a few apps.
Murph
Supporting the troops daily.
MARZMILLER
Yes. In "Toolspace", go to the "Toolbox" tab, expand "Miscellaneous Utilities", expand "Export KML", right-click "Export KML" and click "Execute..." I understand that this thread is almost a year old, so this is mainly for the folks that are Google-ing this question.
rrustan
in reply to: MARZMILLER
You must have Civil 3d 2015. Map does not have toolspace.
olivier.eckmann
if you are under subscription, you can install MAP 3D 2012 + GoogleEarth Plugin which add a nice wizard to export AutoCAD Objects (2D and 3D) to KML or KMZ
Olivier
rtopping
This works from Civil 3D but not from Map 3d:
In "Toolspace", go to the "Toolbox" tab, expand "Miscellaneous Utilities", expand "Export KML", right-click "Export KML" and click "Execute..." .
kalman_albert
You can try our advanced Export KML plugin from Autodesk apps store.
https://apps.autodesk.com/CIV3D/en/Detail/Index?id=6995279902965544097&appLang=en&os=Win32_64
Albert
"Nothing will ever be as it was!"
”Boost
