What you wanted was to create a polygon topology, and query the areas of the resulting polygons. I took the liberty of doing this, and have attached the file below. The point objects are the topology centroids, query those for the area of the polygon it belongs to.
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
