AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
bylayer
2 REPLIES 2
338 Views, 2 Replies
bylayer
is there a setting?
colour and linetype to bylayer for drawings originating in civilcad, liscad no problem but lineweight which i set to default only plots as a thin line, using ctb file.
2 REPLIES 2
pendean
LWIEGHT command? Type it.
thanks, but makes no difference.
should mention that this is not a problem on another machine, and both apparently setup in the same basic manner
”Boost
