AutoCAD Map 3D General Discussion
neilyj
Message 11 of 18 (1,609 Views)
Re: Bring csv file (with additional attributes) into Map
05-15-2012 05:26 AM in reply to: Murph
I have tried this and the additional attributes are visible in C3D but the SDF export seems to ignore them. The lines below show the data I am tryingto work with - there are more fields in the full dataset but these are the main ones of interest at the moment
#PtENNameDescriptionRegion
1278200647200CanderiggLochhead/BroomfieldSth. Lanarks
2279100648700Woodside Colliery Sth. Lanarks
3297900689000Bogside Mine West Fife
4347300709200Highham FarmRadernieEast Fife
5280000645700East Draffan Sth. Lanarks
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Murph
Message 12 of 18 (1,606 Views)
05-15-2012 05:46 AM in reply to: neilyj
I'll tinker with it later today, got some boats engines to get running first. :smileyhappy:
Murph
Supportting the troops daily.
Distinguished Mentor
thepworth
Message 13 of 18 (1,601 Views)
05-15-2012 07:19 AM in reply to: neilyj
Neily,
I was able to connect to your data via FDO ODBC to Excel.
I've got the current 64-bit Access ODBC driver and 32-bit Office 2007.
From Excel - highlight all of your data & set up a "named range"
From the ODBC data sources in Control Panel, Create a DSN to the Excel workbook.
From Data Connect in Map/C3D, select the DSN from a FDO to ODBC.
You should see the named range & X/Y/Z columns - select your easting & northing & points should come into the  workspace.
Update if you need more help...  I didn't have to modify anything you posted  regarding characters...
Best of Luck!
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
neilyj
Message 14 of 18 (1,598 Views)
05-15-2012 07:26 AM in reply to: neilyj
Thanks for trying the odbc method - but this will mean an uninstall and reinstall of office 2007 which I'd prefer to avoid if at all possible
neilyj
thepworth
Message 15 of 18 (1,596 Views)
05-15-2012 07:30 AM in reply to: neilyj
You are correct.  However, when I uninstalled Office  I was prepared with backing up all of my email/info to a .pst and thought I'd have to reload all of my messages/notes/calendar from it.  Turned out not to be the case - everything was "as-is" prior to the installation.  Dunno if this is because we're on a MS Exchange server, or if some of the settings are retained in the registry (or elsewhere) even with the uninstall (maybe uninstall not complete/clean???)  Won't promise it would be the same for you, but was less painful that monkeying around with a VM..... the only other alternative I could think of for you.
C3D 2011
Active Contributor
CivilFF
Message 16 of 18 (1,565 Views)
06-13-2012 08:24 AM in reply to: neilyj
1. Get your pure data
2. Insert the data to your favorite spreadsheet (in this description I use Microsoft Excel)
3. Save your pure data to the CSV file called CSV (Comma delimited) but notice that you get a semicolon separator ( ; )
4. Create a new Point File Format in Autodesk Civil 3D and call it e.g. PEN(semicolon) with settings:
- Default file extension .csv
- Comment Tag #
- Format options Delimited by ;
5. Import the points to Autodesk Civil 3D from your CSV file
6. Choose Output and Export Civil Object to SDF Set your coordinate system in this example Arbitrary X-Y Coordinates (XY-BC) is used
7. Change the workspace to Autodesk Map 3D (Planning and Analysis)
8. Type a MAPWSPACE command and choose On
9. Connect to the SDF file
10. Choose Points data from Civil_Schema and press Add to Map
11.
The Data Table is empty
12. Export Layer Data to SQLite
13. Open the Mozilla Firefox browser
14. Install Extension called SQLite Manager from Mozilla Add-Ons
15.
From the Mozilla Firefox browser choose Web Developer and open SQLite Manager
16. Open the SQLite Points base exported by Autodesk Map 3D
17. Open the table called Points, select Stucture and copy the statement (mentioned below) to the notepad for future reuse in next steps:
CREATE TABLE "Points" ("Autogenerated_SDF_ID" INTEGER PRIMARY KEY, "Geometry" BLOB, "Name" TEXT, "Description" TEXT, "RawDescription" TEXT, "Number" INTEGER, "Elevation" REAL, "Latitude" TEXT, "Longitude" TEXT)
18. Select Points, choose Export Table and export the data to the CSV file Select the checkboxes: First row contains column names and Fields separated by Semicolon ( ; )
19. Select the exported Points table and delete it
20. Open the exported Points table form the CSV file format in Microsoft Excel
21. Change the column names and copy your data to these empty columns from the pure data CSV file
22. Save the edited CSV file as the CSV format file
23. Go back to SQLite Manager and import the edited CSV file
- Select First row containing column names
- Select Fields separated by Semicolon ( ; )
24. Set types of data for all columns from the information that you have saved in the notepad:
Autogenerated_SDF_ID -> INTEGER
Geometry - > BLOB
Name - > TEXT
… etc.
25. Save and Close SQLite Manager
26. Go Back to Autodesk Map 3D and connect to the re-edited SQLite database
27.
Select Points and Add to Map
28. Finally you will get your points from Civil 3D with data from the CSV table, other words you have just inserted all pure data
If you check the result - geometry matches the description.
CivilFF
www.civilfastforward.com
neilyj
Message 17 of 18 (1,558 Views)
06-13-2012 08:43 AM in reply to: CivilFF
CivilFF - Thanks for taking the time to produce the instructions and screen shots, I'll give it a try and see if I can get it to work.
Incidentally, it seems like we have to jump through several hoops to get any useful data exchange between Map and C3D - it really shouldn't be this involved should it??
neilyj
neilyj
Message 18 of 18 (1,531 Views)
06-15-2012 02:10 AM in reply to: CivilFF
Just worked through this and it worked like a charm - it's not a procedure you just stumble upon though....!!!!:smileyhappy:
neilyj
