AutoCAD Map 3D General Discussion
neilyj
Message 1 of 18 (750 Views)
Bring csv file (with additional attributes) into Map
750 Views, 17 Replies
05-14-2012 12:47 AM
I found this post which describes exactly what I want to do to get data into Map http://map3d.wordpress.com/2008/01/02/bring-a-csv-file-into-map-3d-with-data/ but I get stuck almost at the first hurdle (see screenshot).
Isn't there any easier way to get this data into Map??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
1. Get your pure data
2. Insert the data to your favorite spreadsheet (in this description I use Microsoft Excel)
3. Save your pure data to the CSV file called CSV (Comma delimited) but notice that you get a semicolon separator ( ; )
4. Create a new Point File Format in Autodesk Civil 3D and call it e.g. PEN(semicolon) with settings:
- Default file extension .csv
- Comment Tag #
- Format options Delimited by ;
5. Import the points to Autodesk Civil 3D from your CSV file
6. Choose Output and Export Civil Object to SDF Set your coordinate system in this example Arbitrary X-Y Coordinates (XY-BC) is used
7. Change the workspace to Autodesk Map 3D (Planning and Analysis)
8. Type a MAPWSPACE command and choose On
9. Connect to the SDF file
10. Choose Points data from Civil_Schema and press Add to Map
11.
The Data Table is empty
12. Export Layer Data to SQLite
13. Open the Mozilla Firefox browser
14. Install Extension called SQLite Manager from Mozilla Add-Ons
15.
From the Mozilla Firefox browser choose Web Developer and open SQLite Manager
16. Open the SQLite Points base exported by Autodesk Map 3D
17. Open the table called Points, select Stucture and copy the statement (mentioned below) to the notepad for future reuse in next steps:
CREATE TABLE "Points" ("Autogenerated_SDF_ID" INTEGER PRIMARY KEY, "Geometry" BLOB, "Name" TEXT, "Description" TEXT, "RawDescription" TEXT, "Number" INTEGER, "Elevation" REAL, "Latitude" TEXT, "Longitude" TEXT)
18. Select Points, choose Export Table and export the data to the CSV file Select the checkboxes: First row contains column names and Fields separated by Semicolon ( ; )
19. Select the exported Points table and delete it
20. Open the exported Points table form the CSV file format in Microsoft Excel
21. Change the column names and copy your data to these empty columns from the pure data CSV file
22. Save the edited CSV file as the CSV format file
23. Go back to SQLite Manager and import the edited CSV file
- Select First row containing column names
- Select Fields separated by Semicolon ( ; )
24. Set types of data for all columns from the information that you have saved in the notepad:
Autogenerated_SDF_ID -> INTEGER
Geometry - > BLOB
Name - > TEXT
… etc.
25. Save and Close SQLite Manager
26. Go Back to Autodesk Map 3D and connect to the re-edited SQLite database
27.
Select Points and Add to Map
28. Finally you will get your points from Civil 3D with data from the CSV table, other words you have just inserted all pure data
If you check the result - geometry matches the description.
Valued Mentor
parkr4st
Message 2 of 18 (741 Views)
Re: Bring csv file (with additional attributes) into Map
05-14-2012 02:12 AM in reply to: neilyj
search this forum for 64 bit odbc.
New Member
jimyquick
Message 3 of 18 (723 Views)
05-14-2012 09:18 AM in reply to: neilyj
Distinguished Mentor
thepworth
Message 4 of 18 (715 Views)
05-14-2012 11:01 AM in reply to: neilyj
Neily,
Murph's post was for the 2008 version - more functionality (i.e. the survey tab under mapwspace) has been added, but you can still follow through & use ODBC to connect to Excel.  If using ODBC, you must use a named range in Excel and have the current 64bit excel driver.
If you're really stuck, send me a PM and I'll see what I can do to help walk you through it.
Todd Hepworth, P.E.
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
neilyj
Message 5 of 18 (710 Views)
05-14-2012 12:52 PM in reply to: jimyquick
Gracias por esto voy a echarle un vistazo (from Google translate....)
neilyj
neilyj
Message 6 of 18 (707 Views)
05-14-2012 12:55 PM in reply to: thepworth
thepworth wrote:
Neily,
Todd Hepworth, P.E.
Thanks Todd, I only have 32 bit Office so will need to look at the link in the post from jimyquick....
neilyj
thepworth
Message 7 of 18 (704 Views)
05-14-2012 12:58 PM in reply to: neilyj
I also only have 32 bit office.
What I had to do was to uninstall office, install the 64-bit Access driver, reinstall 32-bit office over the 64-bit driver - you can't update the driver with 32-bit office on the machine.
Then use a named range in excel - this is critical.
Worked for me only after upgrading to 2012 - wouldn't work with C3D 2011 for ODBC to excel.
HTH!
C3D 2011
Murph
Message 8 of 18 (699 Views)
05-14-2012 02:59 PM in reply to: neilyj
Yes with the newer version (2010 and up) Use the Mapimport and select the ASCII format, You may need to edit the CVS file a bit but that's one way with out ODBC.
Murph
Supportting the troops daily.
neilyj
Message 9 of 18 (688 Views)
05-15-2012 02:30 AM in reply to: Murph
Thanks for this but when I try the ASCII file, there doesn't seem to be an option to change the input fields....
neilyj
Murph
Message 10 of 18 (677 Views)
05-15-2012 05:14 AM in reply to: neilyj
Neilyj, If you have C3D why not just use the Civil3D opint import tools and create the format you need? Once you import the the cvs as points do a export to Geospatial of that point group to SDF format.
Can you attach a few lines of the CVS file?
Murph
