AutoCAD Map 3D General Discussion
Active Contributor
Mennonite789
Message 1 of 2 (366 Views)
Block Reference Scale Issue
366 Views, 1 Replies
09-27-2012 02:06 PM
I'm working with two different drawings to import Layers for Lot Grading and when I'm importing the Block Reference from the origin file, it's setup as Linescale 0.5, but when I import into my regular basemap, which is setup for Linescale 1, the text size is double what it should be.  Is there a method for fixing this on my regular basemap, or do I have to setup something in the Origin File to fix this?  Thanks.
Active Contributor
Mennonite789
Message 2 of 2 (333 Views)
Re: Block Reference Scale Issue
10-01-2012 10:04 AM in reply to: Mennonite789
Problem turned out to be the Block Reference's themselves.  What had happened was when you import the Block Reference, somehow the text height didn't change, and instead you had the text field overlapping the box window it's supposedt to be.  To fix this, open up the Block Reference Editor, and when you select the affected boxes, edit attribute, then change the height of the text to something that works for your project.
