HI!
Is it possible to create block where attribute values comes directly from database(oracle, etc). When date is changing in database then attribute valu also changing in block.
Seems it impossible to do without programming.
Right now i use solution like this: at first I created database links with blocks and after that added annotation to block. When data is changing I can update annotation.
Anyone have done similar like this?
