If the title dwg was a seperate dwg file that conntained attributes and you
inserted it into your current dwg then you need to open that titleblock
BLOCK in the block editor (bedit command) and make the changes there.
Changing the justifaction in the orginal dwg does not update any dwgs that
it is inserted into. Another way is to delete the bloc and purge it out of
the dwg then insert the edited dwg again.
Murph
http://map3d.wordpress.com
___________________
wrote in message news:6334792@discussion.autodesk.com...
Hey M,
I've already tried that...it didn't update...do I have to make it a
BLOCK?...right now it's just no block at all, with attributes
attached...when i start a new drawing...I insert it as a BLOCK in LAYOUT
space, and lets say I noticed theres a mistake in one of the attributes and
I go ahead and make that change in the original file that contains the
attribute..resave it as a dwg AND a dwt, went back into my drawing...did the
battman, did the sync, the update didn't change...am i missing something
here?..
Another way I did was using the ATTSYNC command...that seemed to work for
individual changes...but I'd rather say that's a little time consuming
there.
