AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
BIM in GEOSPATIAL
4 REPLIES 4
255 Views, 4 Replies
BIM in GEOSPATIAL
im working on getting an ADT "building information model" within the mapguide. when i publish the 3d model from ADT 2005 to MAP3d 2007 i get an error message:
"SDF file appears to be version 2.1 or older. please convert to SDF version 3.0"
is there a known solution for this problem? is there an sdf converter i can use?
thanks
4 REPLIES 4
You can try this
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7785535&linkID=2786655
Don't know how well it will work with ADT objects you may have to dumb them
down to simple AutoCAD objects and classify them in map.
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
wrote in message news:5484416@discussion.autodesk.com...
error message:
3.0"
use?
thanks
thank you murph. i will try this solution and post the results.
this solution cant work for me since it creates the SDF3 from map2007. i need to somehow create the SDF3 from within ADT 2005 so that I can retain ADT's IFC framework and have it export it to map 2007.
Didn't think it would, you might ask in the ADT groups if there is a way to
export to a format that would keep the ADT objects but I don't know of any.
Murph
wrote in message news:5486748@discussion.autodesk.com...
”Boost
