AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Big problem starting AutoCAD Map 3D 2013...
11 REPLIES 11
Message 1 of 12
iam_doss
2986 Views, 11 Replies
Hi. I have a problem to run Map 2013 today. Here the message:
"System.IO.FileLoadException: Can't load procedure from 'MapPublishImp.dll'.
File name: 'MapPublishImp.dll' in Autodesk.Gis.Map.TextEdit.UI.MapPublishHelper.Finalize()"
Fatal error and Map is closed
What I have done:
- Try to repair and reinstall, nothing
- Uninstall Map 2013, delete all program's and user's folders and clean Windows Registry, clean install of Map 2013, NOTHING (???)
I don't know what can I do. PLEASE HELP
Thank in advance
11 REPLIES 11
Message 2 of 12
iam_doss
in reply to: iam_doss
Some more info that I can read before close Map:
Map can't find some procedures or load failed for:
- acmapworkspace.arx
- acmapdwfapi.arx
- acmapcogo.arx
- AcMapDwfUI.arx
- AcMapAnnotUi.arx
- acmgd.dll
- bin\maptoacad.arx
Message 3 of 12
braudpat
Hello
Strange ...
Which MAP 2013 : version 32 or 64 bits version ?
On Win XP Pro 32/64 or on Win Seven 32/64 ?
Have you installed others Autodesk Software just before having the probleme ?
or any other Software ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 12
fieldguy
in reply to: braudpat
Have you tried "Run as administrator"?
Message 5 of 12
iam_doss
@braudpat wrote:
Hello
Strange ...
Bye, Pat
Hello Pat, thanks you for your answer. Win7-64 and Map 2013-64. No, I have not installed others Autodesk nor any other software just before this problem. Past Thursday I have tried to play with MAPPUBLISHTOMAPGUIDE, but I have got an error because trying to connect to a Mapguide 2010 Server, and, it seems, from Map 2013 I need an AIMS 2013 Server to run this command. Well, I have closed Map without problems and today is the first time I have started Map 2013
Message 6 of 12
iam_doss
in reply to: fieldguy
Thanks but don't works
Message 7 of 12
matus.brlit
I have the same problem with Civil 3D 2013.
The problem showed on 2 computers, one is win XP 32-bit, one is win 7 64-bit.
On both computers i was able to run AutoCAD after install. Problem started on one computer after using acad.cuix from Civil 2012. On the other computer the old ciu worked fine, but the problem started after an application created new profile.
I tried to install servicepack, repair, reinstall. Then I uninstalled and install again. That helped.
But after using the another cuix, the problem returned.
edit: Actually it seems like both of these cases are cause by the same thing, because the application uses its own cuix file. So the main cause of this is the cuix that didn't come from the installation. But I have another 7 computers, where it works with replaced cuix.
Message 8 of 12
matus.brlit
in reply to: matus.brlit
So I reinstalled it again and now I didn't replace the cuix, I just imported the saved profile. I got the error about missing cuix, turned off Civil and could not start it again because of this error.
Message 9 of 12
matus.brlit
My solution:
In Civil 2013, there is a new path between support file paths
YourCivilInstall\bin\fdo
After I added this path to my custom profile, the file loads without problems
Message 10 of 12
acruz
Hi iam_doss, did you find a solution?
I'm experiencing the same thing. Could you please share what's your solution.
Thanks.
Message 11 of 12
Spatial-Manager
in reply to: acruz
Spoiler
The only workaround I found was to restore windows to a restore point previous to failure
Message 12 of 12
acruz
in reply to: Spatial-Manager
Thanks SpatialManager for the reply. But earlier, I tried repairing the Map 3D and installing its SP 2. The errors disappeard after SP 2.
”Boost
