AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Bearing Annotation rounding / displaying issue
3 REPLIES 3
TimGIS
694 Views, 3 Replies
Using Annotation to place a Distance and Bearing text via the great post from Murph (Label Those Lot Lines,) I seem to have an inconsistent display of my bearings when the bearing is close to 0. I built the file using Civil 3D but switched to Map3D which doesn't seem to have access to Ambient Setting anymore either.
Using a simple polyline and with my units and precision set as per the blog (Surveyor Units, Precision of 0.000000), sometimes a bearing of N0d13'00'E will show up as just "N".
I need to see that it is 13 minutes.  Can anyone help?
Tim
3 REPLIES 3
Murph_Map
in reply to: TimGIS
Tim
Tim,
I'll go back and review that post (it's been a while) and see if there is anything to get it to display the 0.
No guarantee. 😉
Murph
Supporting the troops daily.
Murph_Map
in reply to: TimGIS
Works ok for me as long as the line was created with survey units input.
I created the line by picking a sp then used 50<N0d13'25"E as the next point.
Look at the property angle of the line and see what it lists. You may have to erase the line and redraw it using the input Distance<N0DXX'xx" with XX & xx as the min & sec you want.
Murph
TimGIS
in reply to: Murph_Map
Looks like its a Polyline vs Line issue. It works fine with the line object but not the polyline object. See attachment
I prefer to use polyline objects due to my GIS work but maybe I need to do all my prework as Line Objects (gross.) All my polylines are of the Surveyor Type input (Distance<N0DXX'xx", yet its just the Annotation (by way of the annotation template) that is rounding the value of N0D13'00"E to  just S
If you have any further thoughts on why annotation rounds to S on a polyline but not a line that would be great. Please test with N0D13'00"E. Otherwise, thanks so much for your reply.
Tim
”Boost
