We're working in Map 5 and LDD3. There are a few
hundred maps we have in
NAD83 that we would like to convert to NAD27 for backward compatibility
with
older data. Does anyone know a way we could query the drawings into
NAD27
and save to a new name or even the existing name in one batch? We could
do
them one at a time but that would be time consuming.
Thanks for your attention.
Allen
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Mark McIntyre" <Allen
href="mailto:markmc@ci.grandjct.co.us">markmc@ci.grandjct.co.us> wrote
in message
href="news:3E273002.27AE787E@ci.grandjct.co.us">news:3E273002.27AE787E@ci.grandjct.co.us...
- Just open a new drawing in MAP, Right click on the "Project" in the project
work space, select Coordinate System from the drop down menu, Select the
Coord. Sys. that you want to work in (NAD 27?) then use the "select drawings"
button to select the source drawing(s) you want to bring into your new
project, select the Corrd. Sys. they are in (NAD83?) and say OK. Now attach
those source drawings to your project and query ALL in the DRAW mode. This
should bring the drawing(s) into the NAD27 coordinate system of your choice.
Sorry this is a condensed veersion. Try the online help. It's pretty good.
Mark
backward compatibility with
query the drawings into NAD27
existing name in one batch? We could do
Allen
"Allen Jessup" <
href="mailto:jessupa@co.rockland.ny.us">jessupa@co.rockland.ny.us>
wrote in message
href="news:A82C8C0A58BBF12E58E9A4A88A611913@in.WebX.maYIadrTaRb">news:A82C8C0A58BBF12E58E9A4A88A6......
Mark,
Thank you for your reply. I may not have bee quite clear in my
description of what we want to do. We can do as you have described. However
that will give us one huge drawing containing all the data from the 250+
drawings. Or we could do each drawing one at a time. What I want to do is to
start with 250 drawings in New York East NAD 83 Feet and end up with 250
separate drawings in New York East NAD 27 Feet. I know there are
programs, like Blue Marble, that will do this but due to budget constraints I
can't purchase anything at the moment.
Allen
wrote in message
project work space, select Coordinate System from the drop down menu, Select
the Coord. Sys. that you want to work in (NAD 27?) then use the "select
drawings" button to select the source drawing(s) you want to bring into your
new project, select the Corrd. Sys. they are in (NAD83?) and say OK. Now
attach those source drawings to your project and query ALL in the DRAW mode.
This should bring the drawing(s) into the NAD27 coordinate system of your
choice.
pretty good.
Mark
for backward compatibility with
could query the drawings into NAD27
Allen
"Murph" <Jmurphy@cemc.org>
wrote in message
href="news:107F128A1AE1129D13D13F17F8B23675@in.WebX.maYIadrTaRb">news:107F128A1AE1129D13D13F17F8B......
So Allen how is your Lisping skills? I think you
should be able to write a lsp to convert them. Then use the script-pro to
batch process them. If you need some help let us know. But it sounds
like an easy task to do.
Murph
"Allen Jessup" <
wrote in message
href="news:76B4504F8EB7CE0C9453C10EB61BA66F@in.WebX.maYIadrTaRb">news:76B4504F8EB7CE0C9453C10EB61......
Yes. That's what I will have to do. I was trying
to avoid it since I'm in the middle of trying to write a lisp to do some other
manipulations to the same data. That's when I have a moment. Thanks for the
offer of help. If I get stuck I'll post my problem
Allen
wrote in message
href="news:107F128A1AE1129D13D13F17F8B23675@in.WebX.maYIadrTaRb">news:107F128A1AE1129D13D13F17F......
you should be able to write a lsp to convert them. Then use the script-pro
to batch process them. If you need some help let us know. But it
sounds like an easy task to do.
Murph
size=2>
"Allen Jessup" <
wrote in message
Allen
wrote in message
Murph
size=2>
wrote in message
href="news:959D0427A3D2A2D5E6FC33ED86DB1340@in.WebX.maYIadrTaRb">news:959D0427A3D2A2D5E6FC33ED86D......
I been looking into it, (it's TGIF, what else to
do) What I would do is start a blank project and set the coordiates to nad27
then attach the dwg one at a time, use the adesetcrdsys command with cmddia
and filedia set to 0 to do it a the command line to get an idea on doing the
lsp. Then do a draw all query, wblock that out to a new dwg file then erase
all, then do the next. It may take some time to create a script with all 250
maps but sounds like a fun project.
Murph
"Jim Borries" <
href="mailto:jimb@pinncomp.com">jimb@pinncomp.com> wrote in message
href="news:4F53C62E05630374DE85E31CBBB47C7B@in.WebX.maYIadrTaRb">news:4F53C62E05630374DE85E31CBBB......
If you do one query, then save it and check "Save to
External File" in the Save Current Query dialog box, you should have the basic
statements for your LISP routine. (Open the .qry file with a text editor
to see the LISP code.)
Jim B.
