AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Bad links - error link to nonexisting row
2 REPLIES 2
245 Views, 2 Replies
I will try to explain
I recently got to examine some externally manufactured data. The
original data had many link templates (to the same database) that had to
be connected to our database. After attaching our database I queried
all the drawings (36 sections) in one drawing. During the generation of
links, 52 could not be generated. All occured in one sections. The
keys and the data are correct. The original link template does work.
Under DBconnect I tried synchronizing those links and I got a - link to
nonexisting row- error.
Any ideas,
Thank you in advance
if the problem is still unclear I will try to elaborate, but I am just
confused about this.
Timothy Connet
GIS Specialist
Sawyer County Land Record Department
10610 Main Street - Courthouse
P.O. Box 248
Hayward, Wisconsin 54843-0248
gis@sawyercountygov.org
Office Phone Number (715) 634-3564
Desk Phone Number (715) 638-3261
Fax Number (715) 634-8185
2 REPLIES 2
The error suggests that the keys in your drawing do not have a matching
record in the linked table.
If the values used to generate links in the drawing look correct and should
have a matching record in the table try the following...
Check the keys to be sure there are no hidden characters...
trailing/preceding spaces?
Check the Link Template definition in this section drawing to be sure it
references the correct field type.
If you still have problems, try deleting this link template from the section
drawing and redefining it.
Good luck,
Will
"GIS" wrote in message
news:3C5EF470.BAF517AD@airstreamcomm.net...
> Any ideas,
> Timothy Connet
> GIS Specialist
> P.O. Box 248
Here is the solution that worked:
Under Express Tools
-use Sync Attributed Blocks to Table or AttSync
Done
> Any ideas,
> Timothy Connet
> GIS Specialist
> P.O. Box 248
Timothy Connet
GIS Specialist
P.O. Box 248
”Boost
